i have the hercules dj concule mk2 and i hook my turntable to the left side ch. 1 but when i click rip vinyl it says impossible to find lame encodes DLL...but the screen comes up i press record but nothing happens what do i do????
Posted Fri 22 Sep 06 @ 6:59 pm
alrite mate
no worries
if you simply go to google and search for the lame encoder , and download it and place the Dll file in the main vdj program folder all will be well
hope this helps!
no worries
hope this helps!
Posted Fri 22 Sep 06 @ 9:22 pm
