One of great possibility of EFX1000 is that you can make a sample (a loop), and can change the rythm inside. Each time you change the rythm, these changes are recorded.
So when the sample reloops, you can hear the rythm modifications you made before... and so on....
The problem with VDJ: it hears to be a delay :
- First : when you change the rythm in live. You push the button but the change are not in real time
- Second : when the sample reloop, the changes of rythm recorded are not at the same time than during the live modification.
I find not solution to solve this problem. The solution "empty buffer" does not work.
Posted Thu 21 Sep 06 @ 4:51 pm
the only solution should be to get the position of song when changing parameter, like for OnStart
HRESULT __stdcall CPlugin ::OnParameter(int id, int pos)
Posted Mon 25 Sep 06 @ 12:27 pm
