Topic: How powerful does a laptop need to be for VDJ
Hi guys I'm looking to buy a laptop just for VDJ and all the music and nothing else. Can you give any input .thanks Phil
Posted Wed 20 Sep 06 @ 12:59 pm
xeonPRO InfinityModeratorMember since 2004
The minimum requirement to run Virtual DJ is:
PIII 850 MhZ computer
1024x768 SVGA video
DirectX compatible soundcard
512 MB RAM
20 MB free on the hard-drive
The recommended configuration is:
PIV 3 GhZ computer
1024x768 SVGA video
4.1 DirectX compatible soundcard (with front and rear separate outputs)
1024 MB RAM
200 MB free on the hard-drive
Posted Wed 20 Sep 06 @ 1:26 pm
sbangsPRO InfinityMember since 2004
Posted Wed 20 Sep 06 @ 1:42 pm
Thanks XEON how many songs you think can fit on that hard drive without slowing it down
Posted Wed 20 Sep 06 @ 1:58 pm
DJ-ALFPRO InfinityModeratorMember since 2005
The hard disk are slowing down when you get over half of it's size but it is not so bad in new models with big cache memory (16Mb model).
Posted Wed 20 Sep 06 @ 2:05 pm
DO you guys have a favorite PC brand and model that i can look into
Posted Wed 20 Sep 06 @ 2:09 pm
well.. i have one :D Apple MacBook PRO :P
But you'll have to wait to VDJ 4 mac ;)
But you can buy any pc that has good components (fast disc & ram, core duo processor, good graphic card, possibly ATI,...)
Posted Wed 20 Sep 06 @ 2:12 pm
Ohm_RSAPRO InfinityMember since 2006
I have an LG 1.7 Centrino and VDJ works no problem! I'd recommend LG or SONY VAIO if its in your budget!
Posted Thu 21 Sep 06 @ 7:31 am
For audio maybe. If the specs I've been told to go with for a desktop to run viddeo I don't think they make a laptop powerful enough for video!
Posted Fri 22 Sep 06 @ 5:18 am
Hi,
VDJ will work better on a computer with dual core... ;)
Posted Fri 22 Sep 06 @ 4:01 pm
