Hello, why is it that with 3.4 you could leave the needle on the record the whole time and only move it when you basically wanted to and everything would be fine. In VDJ4 when u drop the needle sometimes the software just starts browsing through browser folders really fast and it doesnt stop until you lift the needle. Do you know how i correct this issue?
Posted Tue 12 Sep 06 @ 2:54 pm
strange problem.. :) never heard of it. i didn't try TC with v4 yet.
Anybody?
Anybody?
Posted Tue 12 Sep 06 @ 3:08 pm
Just disable browser in the TC config options. The browser should only work in the last 2 min of the TCV
Posted Tue 12 Sep 06 @ 3:15 pm
Its a new feature in v4, it allows you to use last minutes of the vinyl to browse the folder and load a song by putting the needle at the start of the tcv...
It is enabled by default, just disable it "browser track" in tc options.
Posted Tue 12 Sep 06 @ 3:54 pm
wow didn't know that. I like it :D
any more feature in v4 that i don't know of? :))))))))))))))))))
Posted Tue 12 Sep 06 @ 4:24 pm
it would be nice if i could search the folders aswell as the contents and switch between the two using the TCV, i had found on more than one occasion that the folder scroll happened spontaniously and i have since dissabled it
Posted Tue 12 Sep 06 @ 10:42 pm
