I am going to purchase 4.O pro, but have a couple questions on the purchase page.
How do I know if it is a download (and discounted) or being mailed?
I got up to the screen that asks you for your credit card, then had to run.
After that, does it give me an option for downloading the software or receive by mail?
If I download, are the 2 TCV still sent by mail separately?
Thanks.
Thanks.
Posted Mon 11 Sep 06 @ 4:19 am
You will get a link to download the software. Once you register your software on the forum you can download it again if you need to. The TCVs will come in the mail seperately.
Posted Mon 11 Sep 06 @ 4:56 am
Thanks.
Posted Mon 11 Sep 06 @ 5:57 am
Sorry- 1 more thing...
I plan on downloading 4.0 Pro to my desktop, but using it on a laptop I'll get in 2 weeks. I do not want to hook the laptop up at all to the internet to download the software.
What will be the easiest way to get all of the program (as it would on the desktop) to be on the laptop from the desktop?
Seems easy enough.
Thanks!
Seems easy enough.
Thanks!
Posted Mon 11 Sep 06 @ 5:59 am
I would burn it to a CD or put it on a USB Drive. (It's not a really really big install, it will fit on a 512meg drive.)
Posted Mon 11 Sep 06 @ 6:02 am
