How if V. 4 supposed to be hooked up to surround? When your in the version and your in config then setting what should it be set too? Its only playing out of 2 out of 5 speakers?
Posted Sun 10 Sep 06 @ 8:22 pm
Every music is stereo, so 2 channels. And VDJ support 2 outs, so 2 x mono. You can allways make surround using external components or software. I have 5.1 sound with dolby digital for example. YOu can do whatever you want with software for yout sound card.
Posted Sun 10 Sep 06 @ 8:46 pm
I guess my question is.....I have 5.1 sourrounf but cant figure out the hook up? its only playing out of the right and left front speakers not the rear or middle???
Posted Sun 10 Sep 06 @ 8:48 pm
Look for any software for your sound card.
Posted Sun 10 Sep 06 @ 9:18 pm
