opened vdj at my gig last night and got this message.
the internal database is corruped.
hit ok and all my saved stuff was gone. and the program acted slow all night . what do i do
Posted Sat 09 Sep 06 @ 2:18 pm
Go back to your most recent backup. You do make backups right?!
Posted Sat 09 Sep 06 @ 2:34 pm
not to sound stupit. but no i havent done a back latley i have only have this program 2 weeks since the show in ac and dont even know how to back you the stuff in vdj. its my bad but still what do i dofrom here
Posted Sat 09 Sep 06 @ 2:43 pm
The database is made of TAGS..
It has a START TAG ... like this <song>
End an END TAG .. like this </song>
And its made of parent and child threes..
Look inside your XML database (open in XML editor or Notepad)
First check the beginning, and end of the whole document
So see if ALL start tags in the beginning, have end tags at the end.
A XML editor will often show you the errors, and highlight it....
Hope that helps a bit
Posted Sat 09 Sep 06 @ 4:00 pm
911 help???
Posted Sat 09 Sep 06 @ 5:55 pm
