I have just installed the Denon 1800 skin while running VDJ 4.o and I like many of the features of the Denon skin, however, it does not seem that I am able to access any of the special effects or samples. Is this a bug or am I just missing one of the features. I see the options on the lower right of the screen but I am unable to select/activate the windows. Please advise and forgive me if this concern was already posted. Thanks.
Posted Wed 06 Sep 06 @ 4:46 am
do u have the right pannel active? the denon 1800 skin uses multiple pannels over the browser, so make sure u select the browser pannel, otherwise the other buttons won't matter,also tap the browser buttons twice, as it seems when u hide the browser in a pannel theres a refresh problem, but it will show
Posted Wed 06 Sep 06 @ 5:14 am
tried what you said and I still can't get to the effects, samples or other options, just the music panel displays. If you can offer any other advice I would appreciate it.
Posted Thu 07 Sep 06 @ 4:22 am
change the skin and select the browser then change the skin back, if the browser shows then it's just the refresh problem
Posted Thu 07 Sep 06 @ 4:35 pm
