I designed a new skin, but have no experience with xml. What editor should i use (no text editor). Can i get such an editor freeware ?
Here you can find a screenshot from my design
http://briefcase.yahoo.com/fla59
grtz frans
grtz frans
Posted Sun 03 Sep 06 @ 7:40 pm
sorry, screenshot is on this adres
http://photos.yahoo.com/fla59
Posted Sun 03 Sep 06 @ 8:10 pm
Just google for free XML editors, there are many good ones.
For graphics, use Photoshop or similar.
The skin SDK is here:
http://www.virtualdj.com/support/developers/skin.html
Posted Sun 03 Sep 06 @ 8:12 pm
I used photoshop, which XML editor do you suggest ?
thnx frans
thnx frans
Posted Sun 03 Sep 06 @ 8:17 pm
oh, there are sooo many
I've used this one a lot, works fine and color code parts etc, so pretty smart ...
http://symbolclick.com/
Posted Sun 03 Sep 06 @ 8:25 pm
Google is amazing!
I just typed "recommended xml editors" and got results! :D no hard feelings :)
Posted Sun 03 Sep 06 @ 8:26 pm
thanx a lot, I am going to give it a shot, but when it's to hot, I will be back soon
Bey frans
Bey frans
Posted Sun 03 Sep 06 @ 8:40 pm
Believe it or not I use notepad for xml, I find it to be the easist, I have Oxygen Xml editor , but I really dont feel like learning it,
Posted Sun 03 Sep 06 @ 8:45 pm
Cool idea making a BCD2000 skin ;) Look forward to see the results;) best of luck
Posted Sun 03 Sep 06 @ 8:49 pm
When you like notepad. You could look into this. It is notepad but then with syntax highlighting. This works for lots of programming languages and also for XML. And it is also freeware, including source code!
Ewout
Ewout
Posted Sun 03 Sep 06 @ 9:53 pm
Thanks Superstom I'll check it out
Posted Sun 03 Sep 06 @ 10:20 pm
