Forum: Old versions
Topic: while scratching heavily crash - Page: 2
I dont have those problems anymore. I know how to set up the operating system for performance . It seem if I give advice it never gets used anyway so I wont do it anymore so good luck fixing your problem.
you should not have to tweak the OS for the DJ program. the dj program should be written so that it works flawlessly.
Well thats the way it is .And my system won't crash I can scratch and loop and just about do anything I want and nothing happens.Try disabling video acceleration.
you haven't pounded on it heavily enough then.
Yes I have I went out of my way to make sure just for you.
