Ok so I have two turntables and a mixer all hooked up right. NOW before the upgrade I had them kind of working, well at least vdj heard the sounds coming from the time coded vinyl. Now with ver 4.0 its not hearing any sound.
My mixer has a master output which I have the RCA (Red and White) cord going from there to my Maya44 sounds card. The wire is plugged into Channel 1 & 2. If one deck is to go to each Channel ( Deck 1 - Channel 1 & 2 and Deck 2 Channel 3 & 4) how do I achieve this with only one master output?
I am really getting more and more confused with this whole setup. The instructions on this site are ok, but even they are a little blurry.
I also have a USB mixer, do I need to use that mixer instead? But the USB cords dont connect to my Maya44 sounds card they connect to the computer it self.
So where am I going wrong? What am I missing? Someone please help, thank you sooo much.
Rich :) aka DJ Double Threat
PS What do I only hear sound coming out of my sound card? I cant hear music coming out of my mixer when I attach my head phones, thats the other issue I have.
Posted Fri 01 Sep 06 @ 6:44 pm
the outputs from your turntables should be going to the MAYA inputs(1,2 for 1 TT and 3,4 for the other TT). Then the outputs on the maya go to your mixer inputs. The master output of your mixer is to hook to your amplifier or powered speakers. Someone has areally good example on thier blog. I'll try to find it and post the link.
Here is the link
https://virtualdj.com/blog/Dams/blog738.html
Don't use the Y splitters between the turntables and the mixer unless you intend to use both regular vinyl as well as TCCV. Follow the lines from the TT to the Maya soundcard and the rest is the same.
Hope this helps
Paisan
Here is the link
Hope this helps
Paisan
Posted Sat 02 Sep 06 @ 2:27 am
MANY thanks bud. I will try this out and let you know how everything works. Thanks sooo much
Rich :)
Rich :)
Posted Sat 02 Sep 06 @ 2:47 am
Heres another really good link for setting everything up:
https://virtualdj.com/forums/13647/Software_Technical_Support/TCV_Setup_Manual_and_Additional_Instructions.html
Posted Sat 02 Sep 06 @ 2:56 am
OK so I did this, hooked up my turntables to my sound card and the sounds card outputs go to my mixer. But still nothing. I have a USB mixer (outputs) should I use those too?
My Maya44 sound card is not a USB one. Does that make a difference. This is seriously getting annoying. Why is this so hard to use?
Help anyone, please
Rich :)
Help anyone, please
Rich :)
Posted Mon 04 Sep 06 @ 9:59 pm
Is it that you're not getting a Timecode signal? Check the gain in the asio configurations. For some reason it was set a default to zero for me and took me a little while to notice when I switched to V4
Posted Tue 05 Sep 06 @ 4:08 pm
Isnt there an AutoAdjust Button in VDJ4 ? When calibrating TCV's i mean ?
Getting myself V4 soon , going with 3.2 atm ..
Posted Tue 05 Sep 06 @ 10:13 pm
auto set in 4.0 too :)
Posted Tue 05 Sep 06 @ 10:28 pm
Yeah there is no signal. VDJ doesnt recognize the signal. And I put the gains up higher, they were at 0 but now I have them at around 24.
What else is going on?
Posted Tue 05 Sep 06 @ 11:58 pm
I can only speak from the Maya USB perspective - so does the Maya PCI card also use the Maya Control Panel interface? If so, are the Input Channels 1-4 muted? If not, then check the Mute for the inputs. Does that help?
Posted Wed 06 Sep 06 @ 2:03 am
thats the weird thing, non of the inputs are muted. I do get a ERROR IN THE ASIO SOUND DRIVER message.
Whats that mean, and how do I fix it?
OK dumb question, but do the "ground" connections need to be connected?
Posted Wed 06 Sep 06 @ 2:56 am
Again from the maya usb standpoint, you want the inputs muted (I hope I'm not wrong as I don't have it in front of me at the moment) and outputs on about 3/4. The error message is critical and means you need to reinstall the drivers. The ground connections should be grounded to the computer but I don't think that's your problem.
Posted Thu 07 Sep 06 @ 9:00 pm
just reinstall all drivers, but firts of all unistall them all and erase all the registres on start menu/run/regedit/HKEY_LOCAL_MACHINE/software , and then reinstall all the drivers again, everything shoul be fine now, I got the same problem with my bcd2000 and I did all that and now Everything woks greath.
I hoppe that work's for you
Dj Quintana
Dj Quintana
Posted Thu 07 Sep 06 @ 9:31 pm
THANK YOU SOOO MUCH! I will do this when I get home and see if it works.
Rich :)
Rich :)
Posted Fri 08 Sep 06 @ 12:24 am
here is the message I get. And yes I did reinstall the drivers AND go into REGEDIT
http://vwhaven.photosite.com/Album3/VDJ_Error.jpg
I also have a USB mixer I am using, should I use a regular mixer?
Rich :)
Rich :)
Posted Sun 10 Sep 06 @ 12:38 am
BY the way, I have this Maya44 sound card
http://esi-pro.com/viewProduct.php?pid=62&page=1
Its not the Maya44 USB one. So does this help you guys out?
Rich :)
Rich :)
Posted Sun 10 Sep 06 @ 1:08 am
Any help guys?
Posted Tue 12 Sep 06 @ 6:09 pm
I've heard that maya44 pci doesn't work well in asio mode, get the esiu46dj it works fine for tcvs use, regards.
Posted Tue 12 Sep 06 @ 6:13 pm
I belive you can use the asio for all drivers
Posted Tue 12 Sep 06 @ 6:23 pm
So now I have to return my sound card and get another? Ohh man the drama continues...
Posted Fri 15 Sep 06 @ 11:55 pm
