greetings
i am currently still using 3.4. still working with 4.0 before going live. my question is : why does the volume on my laptop change when i am playing a song on deck one, while i am loading a song on deck 2 ? the volume goes down and i have to reset the volume after the song on deck 2 loads. look forward to any responses.
musicman
musicman
Posted Thu 31 Aug 06 @ 9:27 pm
Did you analyzed your tracks? Did you set in settings to "Always 0db" or "Always match"?
Posted Fri 01 Sep 06 @ 3:40 am
i tried both settings and i still get a little dip in sound when i'm playing one deck and loading the other.
i have a gig of memory on my lap top, i'm never using more 525 mb of memory and my cpu usage is always below 5 %. will analyzing the tracks level all the tracks on my laptop ?
thanks
musicman
thanks
musicman
Posted Fri 01 Sep 06 @ 4:32 am
set it for 0 and make sure ur sound card is configured correctly anylizing alweys helps, do it now and dont wait till u get over 100,000 files, it took my pc weeks to anylyze everything
Posted Fri 01 Sep 06 @ 4:39 am
