This is not big problem but I get the occasional crash when openig VDJ 4.0. I had the same problem with VDJ 3.4, so it's now new. I am not using any plugins except DJ Cel's Hercules Mapper.
Most of the time the software starts ok but the occasional crash at first. When loaded, no issues.
I would still like this though. Any help is much appreciated. :-) thanks
Posted Wed 30 Aug 06 @ 5:59 pm
I would start troubleshooting the by disabling features one by one to narrow down the problem. Try to set the soundcard to simple single output. If that doesn't work try to disable your hercules or midi, and so on. You can even try to disable the soundcard from the device manager and see if it will stop VDJ from crashing. Once you narrow down what's causing the problem, it will be easier to figure out the fix for it.
Posted Wed 30 Aug 06 @ 8:24 pm
Thank you for the information. I'll give it a go.
Posted Wed 30 Aug 06 @ 11:26 pm
