For some reason, if i have one song on one deck, and i load another onto the other, if i go to adjust the eq or anything on the other deck it makes a low sort of cracly noise.. the crossfader also does this, as do the adjusters for the effects..
Do i have a setting wrong or something?
Oh and VDJ asks me for my serial everytime i open it.. can i disable this?
Other than that, very happy with 4.0 :)
Thanks,
Sean
Thanks,
Sean
Posted Wed 30 Aug 06 @ 2:03 am
Hummm, i've got the crackly noise before too, try lowering your performance setting. Mine did it when it was set too high.
Posted Wed 30 Aug 06 @ 2:24 am
Posted Wed 30 Aug 06 @ 1:29 pm
