the Echo V2 has parameters you can modify (ie - # of echos, depth beat adjust, mute song, length of echo, etc) i have settings I use consistently but everytime i close VDJ the settings aren't saved...i have to reset them to my preference everytime i load up vdj, is there a way to save the parameters? please help! Thanks!
Posted Mon 28 Aug 06 @ 8:57 pm
The new plugins SDK for VirtualDj v4.x enables to save the settings so we just need to update the plugin ;-)
Posted Tue 29 Aug 06 @ 12:10 am
so how do you save parameters
Posted Tue 29 Aug 06 @ 4:46 am
The new SDK with examples will be available soon, just wait
Posted Tue 29 Aug 06 @ 12:25 pm
