I'm new to the whole virtual DJ program....
I have a laptop that doesn't have a sound card, so I bought a creative (Sound Blaster) external soundcard. I then hooked it up to a 5.1 surround sound system.
My question is how do I set everything up so that I can hear sound out of my headphone and out of the speakers, so that I can acutally mix properly in a show....what setting so I need to put my virtual dj on in the configuration menu.
Any help is greatly appreciated, and remember, I'm just a beginner
Posted Sun 27 Aug 06 @ 10:18 pm
your gonna need a y -spliiter capable of splitting stereo to left and right mono, afterward plug ur headphones in to either left or right and your amp into the oppisite, make sure u select the proper sound config in the program
Posted Sun 27 Aug 06 @ 10:24 pm
Its pretty straight forward ;)
If you look here, there is a guide with picture on how to setup your soundcard for the use you want:
http://www.virtualdj.com/forums/54145/General_Discussion/Virtual_DJ_4_tips___tricks_(Starter_Guide).html
Hope that helps ;)
If not ask again ;)
Hope that helps ;)
If not ask again ;)
Posted Sun 27 Aug 06 @ 10:25 pm
