After installing version 4 and changing the Sound set up configuration, videos all play at what seems to be quadruple speed. Setupconfig:
Inputs: none
Outputs: External Mixer
Sound Card: ASIO Driver
When the setup is changed to:
Inputs: none
Outputs: Single Output
Sound Card: Simple
The sound and video play normally but only on channel 1 of the mixer.
Any ideas or problems with using the WaveTerminal 192L with Version 4.0?
Thank you,
Larry
Inputs: none
Inputs: none
Sound Card: Simple
Thank you,
Larry
Posted Sat 26 Aug 06 @ 6:17 pm
Use auto on the latency, in the performace tab.
Posted Sun 27 Aug 06 @ 2:25 am
DJ Cyder, you are right on the money. Worked perfectly.
Thank you very much!
Larry
Larry
Posted Sun 27 Aug 06 @ 4:44 pm
No problem larry as a 192l user myself I can tell you this works for me. Also if you set the latency in the wt config to match vdj's it will work too I'm currently using 5ms on both sounds awesome.
Posted Mon 28 Aug 06 @ 4:46 am
I'll give the latency change a try.
It's gettin' better all the time!
Thanks again.
Thanks again.
Posted Mon 28 Aug 06 @ 11:10 am
