Here I go again..
I need your help.
The new sound engine is great, but on the right deck I get an occasional crackling sound. This does not happen with every song and it does NOT occur on the left deck.
I'm using the maya 44. Left for out 1 & 1 and right for 3 & 4. I tried moving the Performance sliders to different settings, but I still hear the occasional crackling sound on the right deck only.
Your input is certainly appreciated. I'm starting to fall in love with this new version.
The Premier DJ Jose
I need your help.
The Premier DJ Jose
Posted Fri 25 Aug 06 @ 7:40 pm
try setting buffer in the performance tab to AUTO...
Posted Fri 25 Aug 06 @ 7:41 pm
Set latency to auto?
Ok
Ok
Posted Fri 25 Aug 06 @ 10:23 pm
JOSETHEDJ wrote :
Here I go again..
I need your help.
The Premier DJ Jose
I need your help.
The Premier DJ Jose
try ASIO drivers
set latency to auto
check safemode and overclock
and the more important : choose the "fast" Martertempo in the performance setiings.
advanced Master tempo made a lot of problems with my PC (and it's a powerfull PC with 1.5 Go of RAM an P4C at 2.8 and ASUS P4P800...)
Now all work fine, if i set Mastertempo at "fast"
Posted Fri 25 Aug 06 @ 10:35 pm
JoseTheDJ, how are you making out with this problem ?
Posted Sat 26 Aug 06 @ 12:43 am
I think that I'm so enthralled by the sofware that I'm living with the occasional pop and click. I will set the latency to auto and lower the settings. My computer runs this software without a performance glitch. Video effects are silky smooth. This is just a matter of a setting change somewhere, hopefully!
I'm just really happy with this new upgrade.
Has anyone found the speedload to be SLOOOOOW. Videos load too slow. I hope this is also as simple as a setting.
Thanks for all your support.
Jose
Jose
Posted Sat 26 Aug 06 @ 1:38 am
In order to load quicker you have to set "SpeedLoad" at "1" instead of "0".
Posted Sat 26 Aug 06 @ 6:47 am
GREAT!
Jose
Jose
Posted Sat 26 Aug 06 @ 4:31 pm
You're welcome ;)
Posted Sun 27 Aug 06 @ 1:05 pm
