Hi,
I'd like to signal that if you open vdj3 and vdj4 (in sequence) and you use them contemporary,
vdj4 does not save the settings and db (shortcuts). I don't know it it happens if you open vdj4 before vdj3, however remember it.
Bye
Bye
Posted Fri 25 Aug 06 @ 2:29 pm
I don't think this happens on mine. But i've copied the entire virtual dj folder to virtualdj3.4 - my shortcut points to there. Have you just copied and renamed the .exe ?
Posted Fri 25 Aug 06 @ 3:44 pm
I just installed the vdj4 ov vdj3.4 :->
then i renamed virtualdj.exe in virtualdj 4.exe and put the old vdj.
this is not the recommended practise on the work pc. (for example crashguard searches for virtualdj.exe....)
However that was just to test, I mixed one song for vdj instance just to take confidence...
It's just that i 've been using vdj out of specs.. :->
Posted Fri 25 Aug 06 @ 10:06 pm
