@pelgrims
- thanx, and will let you know as soon as needed for testing
Posted Fri 25 Aug 06 @ 8:45 pm
Well this is not going away until the issues are resolved. You have just done what other companies call a marketing disaster. You have failed on all parts. The Mic is implamented in the ASIO portion of the Behringer driver and Virtual Dj will have to implemented it that way as a imput source. Just like the TVC vinyl is implemented as a imput source. Do you feel good about the lies you have told for the Virtual Dj team. How much will you guys have to lower yourselves before you see the light.
Posted Fri 25 Aug 06 @ 9:09 pm
DO NOT BE SARCASTIC man, we just have to wait untill they fix it I am sure thay will remember BCD is not part of VDJ so any support from VDJ will be ok
DJ Quintana
Posted Fri 25 Aug 06 @ 9:21 pm
They started this a few months ago promising it would be right and they did this. We went over and over this and you want me to let them get away with this . No way they were hostile when I told people to wait and see before buying the software and they told them it would be on the next release 4.0.They deserve everthing they get .
Posted Fri 25 Aug 06 @ 9:41 pm
Hey I purchased 3.4 because that also but now my bcd ASIO drivers do not work but the bcd as a midi controler does so then just be patient I think what they said they did they made the bcd compactible with VDJ but now we just have to wait until they make 100% compactible with VDJ I hoppe won't be too long
Dj Quintana
Dj Quintana
Posted Fri 25 Aug 06 @ 9:45 pm
So I downloaded the asio4all drivers but the headphones and microphone didnt work. How i got the headpones to work is to add your soundcard and your BCD2000 to the asio4all plugin. Then in the soundcard option you can use your laptop soundcard for headphone use. Now next is to get the microphone working. Did anybody get it working yet???
Thanks
Thanks
Posted Sat 26 Aug 06 @ 12:01 am
They won't get one BCD user until they fix their problems. They won't even say a word now because they know they lied to all of us. They will take another six months to fix the ASIO and still not fix the rest.
Posted Sat 26 Aug 06 @ 10:23 am
Read the posts again and you will see that we asked you what to do to improve the midi in order to use th BCD200 and it was done in v4
Posted Sat 26 Aug 06 @ 1:47 pm
The official word was there was going to be native support for the BCD. This is not the case!
Indeed the question was asked what would be required to make the BCD work, and I know I did post a response that the MIDI implementation would have to be updated to be able to (at least) know the difference between noteON and ContralChange events. This was done, but you cannot send commands back to the BCD when for instance a button is pressed. This causes LEDS to not work as they should be switched on or off by MIDI commands.
If proper native support for the BCD was done this would be much easier to do. It would also allow for stuff like button mapping in a much more flexible way (much like other DJ apps do).
As an example, my regular DJ app allows for loops to shift or be made longer or shorten using button combos on the BCD. I press a button and use the jog to move the loop forward backwards, or move the start/end point. Withe 'just' the MIDI map this would be impossible to do..
Posted Sat 26 Aug 06 @ 2:02 pm
If you had listened you wouldn't be in this position in the first place. You told us native support not primitive support. Also you knew we needed the mic to work. Also you knew it needed to be done with the ASIO drivers. But like always you start lying again to try to cover you butts . The information you seek is on this very forum all you needed to do was read it.
Posted Sat 26 Aug 06 @ 6:16 pm
If things dont work as planned or said, be sure VDJ Dev Team will adress it..
And feel free to use the program that comes with the Behringer console if you dont like VDJ ;)
Its not the first time in software history that said features did not work first time released, that goes for Xylio B-DJ as well as Windows OS.
If you are adult about it, just try to be more friendly and constructive, and I'm sure Dev Team will look into why Asio dont work for Behringer console.
Posted Sat 26 Aug 06 @ 6:22 pm
Just ignore digi(talm)dj.. He's mainly here to troll, more then he's here to actually get this sorted..
Posted Sat 26 Aug 06 @ 7:40 pm
From Wikipedia, the free encyclopedia
A troll is a fearsome member of a mythical anthropomorph race from Scandinavia
Maybe not ;)
Maybe not ;)
Posted Sat 26 Aug 06 @ 8:35 pm
Paulheu doesn't use the dictionary much does he. He was meaning the fishing kind of Trolling . AS to catch a fish. Baiting you into making mistakes. If you want this to stop just stop lying and tell the honest truth. Which is you don't have a clue. We need a date this time when they are going to finish what they promised. Also Behringer is not going to work on the drivers . I went over this with them a long time ago.No more excuses because you used those up a month ago. Now if you can do that then things will get civil but not until then.
Posted Sat 26 Aug 06 @ 8:44 pm
So you think we all lied, all wanted just to make a practical joke and did not intend to support the Behringer model? hehe
Thats ok ;) Believe what you want, I dont care anymore..
Posted Sat 26 Aug 06 @ 8:48 pm
@digitalmdj
Ok we warned you, each time you post, to be more respectful on this forum. As you don't understand what it means, we have all decided to ban you from the forum during 1 day. Take this time to think about it and see you tomorrow with a new mind.
Posted Sat 26 Aug 06 @ 8:51 pm
The other BCD users can now express themselves in peace ;-)
"Welcome to the CONSTRUCTIVE thread about BCD2000" again
Posted Sat 26 Aug 06 @ 9:01 pm
OKay I'm Pissed as well.
I waited 4 months for this software release and all i got was a couple of new looking skins and a "improved sound engine".
Can anyone really tell the fucking difference at 105db in a crowded nightclub?
I've worked clubs for 15 years as a live soundboard operator for the live bands and dj. At that volume NOBODY can tell the bloody difference.
now the bcd 2000 issue.
There are Obviously a lot of cross customers out there. bcd and vdj and dj decks and pcdj; why can't vdj make up it's mind. Support it or don't.
pcdj says nope and puts out it's own remotes, I use the dac-2 it's excellent btw.
djdecks came out with a solution that works just fine (i'm going to be trying the demo REAL soon
I was made a promise by your company and In my opinion that promise has not been met.
I paid good money for this software and i would like to see what my money has paid for.
Haveing a promise half fullfilled is not accepable.
If this was a retail vendor I would be returning your product and demanding a refund.
DJ Marcel
Resident DJ
Purple Onion Nightclub
DJ Marcel
Resident DJ
Posted Sun 27 Aug 06 @ 1:19 am
So, much for ''constructive'' feedback... here we go again?
So, what is your issue? You say you use the dac-2, but don't say you are having problems with the TOPIC at hand? What were 'you' promised?
Please calm replies/statements/questions will get calm answers.
cstoll
cstoll
Posted Sun 27 Aug 06 @ 1:59 am
Ok, to be a little more constructive, here we go:
1:
we asked for a better midi support, you brougth up the jog-wheels. THX for this even if it worked already in V 3.4 (thx to mr bome and his midi translator).
the buttonlights are still not working in the right way, maybe we find a solution for this with the midi translator again, but is this "native support"? What about the pitchbend and search buttons?
2:
the sound engine seems better to me than in V3.4. good work here, but the sound with V3.4 was already not the worst ;)
3:
the asio drivers dont work anymore like they did in V3.4 so it looks to me that the reason for this is caused by VDJ. behringer has made no change in their drivers so it cant be there fault that V4.0 is not working with the asio anymore.
4:
Headphones down in V4.0 -> ASIO?
5:
we asked for mic-support. You said we should try to activate it in the win-soundengine. as you know for more than a day, this is not working. so why are you sugesting this solution over and over? find a way to activate the mic in with VDJ and we all be a little more happy.
6:
anyone tried to use the secondary inputs from the BCD? are they working?
So, please be not astonished that some of us BCD Users are a "little angry" about what you call "native support" ;) let's get a VERY quick workaround for the asio drivers first. and please dont say again behringer is working on this. Again, they had made no changes in their drivers, the reason why VDJ isnt working with them is caused by VDJ. So you should bring up a solution, not behringer.
Last not least, please excuse my english. german would be a little easier for me.
1:
2:
3:
4:
5:
6:
Posted Sun 27 Aug 06 @ 2:56 am
