Help please, just installed VDJ 4 but when I use my hercules MKII there is a gurgling noise when I operate the eq knobs. Can anyone help me solve this bug.
Posted Thu 24 Aug 06 @ 9:30 pm
try to work with the performance tab settings, same thing was happening to me but i turned down the settings a little and the sound became smooth again
mk2 works infinitely better in wdm mode... asio buffers are just too high latency for a lot of things
Posted Thu 24 Aug 06 @ 10:04 pm
I did what you said and it worked. What settings do you have yours at or does it depend on the system that is used. Thanks again.
Yogi.
Yogi.
Posted Thu 24 Aug 06 @ 10:22 pm
it really depends on your system.. higher end and build systems can accomodate better quality settings...
if you post your system specs, maybe we can try to find okay settings (but the REAL test is just listening to it and checking latency)
Posted Thu 24 Aug 06 @ 10:59 pm
Posted Fri 25 Aug 06 @ 12:59 am
If you are using an MK2, these settings were found optimal by some members, please give them a try.
Could a modeator maybe make this sticky.
Posted Fri 25 Aug 06 @ 1:02 am
i know this may sound stooooopid....
but hre goes...
so i have a Mk2
what are the settings in the sound panel to get the bloody thing working properly..
i mean like.. so far, all the settings i have tried seem to identify the console as the headphone as well...please see the this....
https://virtualdj.com/forums/54385/Hardware_Technical_Support/VDJ_4_and_MK2.html
cheers
DJ Rudra
but hre goes...
so i have a Mk2
cheers
DJ Rudra
Posted Sat 26 Aug 06 @ 6:52 am
