IM having trouble trying to mix using the loops created. Let's say I'm trying to fade into the loop safri duo.. drum beat...
well when i pull the song and leave the loop playing.. i try to place another song into the deck and as soon as i begin to play it, it changes the speed (bpm) in the loop and the change is so noticable. Is there any way to resolve this.
If I used a multi virtual dj format.. Would I be able to use one set up for the loops and the other deck for mixing? If so, will the beats in all decks recognize each others?
thanks
thanks
Posted Sat 26 Jun 04 @ 5:08 am
is changes bmp because your loop probably have a beatlock, thats my guess :)
you can turn it of... and fade songs in, by manual pitch to make them fit beat.
turn off beatlock in sample engine (click that little dot on the right side, right under the word "loop" for the slot you are using)
as of multi-decks, sounds possible...
guess a teamer or anyone who have tried can give a good answer...
Posted Sat 26 Jun 04 @ 12:54 pm
