Hi,
I am a VDJ 3.4 Professional user and I am having problems with my sound setup. I am trying to get my BCD2000 to work with the programme, and everything is working perfectly apart from the headphone cueing. I have instructions to use the advanced sound card setup, but on my version I appear to only have 3 options; master only, stereo splitter and 4.1 sound card. Could anyone suggest any ideas??
Cheers,
AFI
Cheers,
AFI
Posted Mon 14 Aug 06 @ 1:13 am
Does your soundcard have more then 1 output?
Posted Mon 14 Aug 06 @ 5:57 am
Maybe scrolling down? =S
Those are the first 3 options in the sound set-up...
xD
xD
Posted Mon 14 Aug 06 @ 6:03 am
Just sorted it, thanks for your help, turns out I was being as stupid as you thought, hadn't scrolled down....... cheers fellas
Posted Tue 15 Aug 06 @ 1:21 am
