Is this possible?
I have some Numark belt drive decks and a hercules console MK1 (which can run in ASIO mode) and I have brought 2 time-codede vynils to use with them. I'm connecting the console to my laptop via USB.
Posted Tue 08 Aug 06 @ 4:55 pm
you can try... some have made it work, but there are some limitations to the MK1 model
- only ONE line in
- a bit slow asio drivers (should not matter much for you maybe, as belt drives turntables are a bit slow too)
Connect the turntable to the line in, and choose timecode at the Hercules optionv inside VDJ.
Choose auto settings, and see if you get good timecode signal
BUT, this only works for 5 minutes in the demo, and you really need the pro version of VDJ ;)
hope that helps
- only ONE line in
hope that helps
Posted Tue 08 Aug 06 @ 5:04 pm
