I ripped a track to the desktop at a gig this weekend, and included to the database search.
Now I want to delete it. THis is what I did.
1. Delete from db search
2. Scan DB
3. Delete from desktop
However this track stil shows in VDJ. It won't allow to delete. Get msg "cannot delete file: cannot read from source disk"
Went to explorer and it is not there. Also did a search in windows for track and it did not find it.
Any suggestion how I can delete this please??
2. Scan DB
Posted Tue 01 Aug 06 @ 6:53 pm
you did all the right stuff , just not in the right order you should have deleted the file first then the database then do a scan, so just do your first 2 again and you'll be fine (delete database, scan database) also FYI you could have also deleted it from the VDj browser just right click
Posted Tue 01 Aug 06 @ 7:00 pm
Phillydj
THanks;
Did like you said. Still found it there. Finally found it in the playlist file.
Deleted playlist rescanned and viola it's gone.
Again thanks, I forgot about the database.
THanks;
Posted Tue 01 Aug 06 @ 8:33 pm
