Hi all,
I'd been having the problem of the VDJ visualisations not responding to the music when i played out usign a DAC-3 & maya 44 soundcard in asio mode (the advanced config mode in the soundcard settings).
Anyway, I've found a way round the problem and i just thoguht i'd post it incase anybody else has had the same problems ;)
What I've done is just use the "timecode vinyl" option in the soundcards tab of config menu. You can play around with the asio settings if you like as well. Then, just disable the timecoded vinyl from within the skin so you don't need it to play.
Easy as that!
Easy as that!
Posted Wed 19 Jul 06 @ 5:17 pm
          doesnt work for me, its never gone with the music for me
    Posted Thu 20 Jul 06 @ 11:50 pm
          that's strange, what soundcard do u have?
    Posted Wed 26 Jul 06 @ 3:05 am
