My new Dell laptop was perfect until a week ago - sound is now jittering abit, just enought to piss you off. I'm only using headphone jack right now - does anyone know if a external sound card would help this?
Posted Sun 16 Jul 06 @ 7:06 pm
What version do U use, demo or? External card are not better than internal, just it is used with laptops. Check for new driver for your sound card.
Posted Sun 16 Jul 06 @ 7:42 pm
Using 3.4 pro - I think it may be time stretch but I'm not yet sure - it can get embarrassing in front of a large crowd.
Posted Sun 16 Jul 06 @ 8:29 pm
3.4 pro? hmmm ...
IF you have purchased this version enter your serial here:
http://www.virtualdj.com/fusers/modifuser.html
regarding the sound issues, might be soundcard, if external, irq conflicts, etc
And some tips for better sound :
- Turn OFF limiter ! (its removed in next version)
- Turn Auto gain to always always zero, or always match at lower than zero db
And the timestrech feature you can turn off too, as its not 100% in 3.4.
Works ok, but its been improved ALOT for 4.0
Posted Sun 16 Jul 06 @ 8:33 pm
seems to have been the time stretch - thanks
Posted Sun 16 Jul 06 @ 9:01 pm
dtrave,
Since you are using virtual dj 3.4 pro, you should edit your profile because on the face of it, it looks like you are using a 'not so legal' version.
Posted Mon 17 Jul 06 @ 5:28 am
