Forum: VirtualDJ Skins
Topic: MOTOR PRO V3 Skin Missing?
What happened to this skin? I can't find it in the Download->Skins section anymore.
Posted Fri 07 Jul 06 @ 11:42 pm
al the tracktor skins are gone from the download-page.
if you search this forum you find out why.
That's too bad! The MOTOR PRO v3 is very, very professional. For me, it continues to be the balance between form and functionality for VDJ skins. It's the skin that drew me to Virtual Dj. Else, I would still be using Traktor. I still use MOTOR PRO with VDJ 3.4 for all my gigs and have found it to be the best.
(A question to the support team). When VDJ 4 comes out and I run the update, will i still be able to use my MOTOR PRO skin? Please let me know in advance so I can continue using VDJ or prepare to move to Traktor 3.
That's the 1st time I see a user choosing a software for its skin and not for its features!
Marius,
Have you used the skin?
Yes, but I won't switch to Traktor if I can't use the skins anymore. Btw, I understand when Traktor asks to remove this skin.
Wow Switching for a skin? Why? You can always make your own skin
