i just bought the m audio fast track pro how do i get it workign with virtual dj. i mean i got it working with it but its not workign with the mixer its control both decks in one out put how do i change that and how can i control the cross fader from my mixer rather then the program. thank you
    Posted Fri 07 Jul 06 @ 11:26 pm
          I have the same problem.....anybody have the solution
    Posted Tue 18 Jul 06 @ 4:31 am
buy the software
Posted Wed 19 Jul 06 @ 1:59 am
          Step 1 = read the manual.
Step 2 = check out this tutorial for setting up the Fast Track Pro with PCDJ. I know PCDJ is different, but the tutorial also explains how to use the multiple outputs on the card in a dj setup.
http://www.m-audio.com/index.php?do=support.faq&ID=6da103b09920a63e1cf11048d1361234
hope this helps,
cF
hope this helps,
cF
Posted Fri 21 Jul 06 @ 10:33 pm
          Multiple outputs are only available in the full version and not in the Demo. That's why PaulHeu mentioned to buy the full version.
Ewout
    Ewout
Posted Sat 22 Jul 06 @ 4:12 pm
