Topic: HELP QUICK
I presume you all no the folder that saves all the songs you've played (it names them by the date they were played). I had a whole set list in their that would have been a great reference to what I'm doing tonight an I tried to rename it and it DISAPEARED!!!! Someone help me quick please!!!! I tried with another folder an the same thing happened!! Where have they gone!!!!????
Posted Fri 30 Jun 06 @ 5:52 pm
Please, some one!!! QUICK!!!! I need to know ASAP!
Buy VDJ for support. Try opening the same folder from windows explorer. Maybe when you renamed it, you erased the .mp3 at the end that's why VDJ won't recognize it. Like I said, maybe.
the pro version is on sale today only for 90 dollars..since u have the console it might be a lil less...anyway the playlist is a .m3u extension so u can just use the windows search to find them
