Topic: Problem
djpuursPRO InfinityMember since 2006
I only have one turntable, when I play a song Vinyl on it and I want to go over to the next song (mp3) on VDJ I can't do it. Is this impossible or have I made a mistake? Greetz
Posted Fri 30 Jun 06 @ 4:23 pm
Hi,
So your problem is when you play a song on the TCV and you load another and it's not playing, right? The solution is pretty simple... press play on the software. Your next song will start.
Karlo.
Posted Fri 30 Jun 06 @ 6:22 pm
I had the same problem, because it was in timecode mode it wouldn't play the other deck without tcv. I got around it by downloading the default 3.4 pro skin, it has timecode bypass buttons for each deck so you can mix mp3 with tcv on one deck and mp3 without tcv on the other;^]
Posted Fri 30 Jun 06 @ 6:38 pm
Can i download it at VDJ site?
Posted Fri 30 Jun 06 @ 8:59 pm
Posted Fri 30 Jun 06 @ 10:12 pm
joetmenPRO InfinityMember since 2005
you can see it here.
Posted Sat 01 Jul 06 @ 10:46 am
Is their a site where I can buy those splitters, because in my neighbourhood their is not a DJ store so. If If I use those splitters I will be able to switch easier from Vinyl to mp3 then I would via bypassmode?Thanks for the help guys.
Posted Sat 01 Jul 06 @ 11:27 am
Posted Sat 01 Jul 06 @ 7:46 pm
djpuurs, any electronics shop which sell hi-fi equipment will sell these splitters.
Posted Sat 01 Jul 06 @ 7:50 pm
DJ Puurs, just go to MediaMarkt. They have those splitters.
Ewout
Posted Sun 02 Jul 06 @ 12:40 pm
Thanks guys.
Posted Sun 02 Jul 06 @ 2:21 pm
