Everytime i play an mp3 through vdj the sound goes up and down at certain parts of the song, but if i play the same file through mediaplayer it sounds fine. What could be the problem?????
i am running vdj pro with dj console mk2.
here are my specs
AMD Xp 3000 on win xp pro
1.5 ghz ddr
160 gb hd
soundblaster live audio
here are my specs
1.5 ghz ddr
160 gb hd
Posted Thu 29 Jun 06 @ 8:47 pm
It controls if Config-Setup FAME you have Time Stretch enable…eventually disable it and tries…
Posted Thu 29 Jun 06 @ 9:18 pm
Disable the Limiter under the FAME tab also.
Posted Thu 29 Jun 06 @ 9:27 pm
Thanks for the help guys ...it worked now it sounds much better.maybe you can help on another problem. i download a cdg file from the net but i cant get my karaoke to display on video.
Posted Fri 30 Jun 06 @ 3:14 am
