Topic: Sound card choice
micbob4PRO InfinityMember since 2006
Which External sound card would you recommend.
1- Sound Blaster Live 24 bit USB S.C.
2- Echo Indio DJ
3- Sound Blaster MP3+
I kind of like the Echo Indio because it is card that I can insert in the HP's card slot without having to use another USB port. Thanks for your help and opinions.
Posted Thu 29 Jun 06 @ 4:10 am
DJ-ALFPRO InfinityModeratorMember since 2005
I have Sound Blaster Live 24 bit USB and it's working fine. Just to know, you can't use TCV's because it has only one stereo input.
Posted Fri 30 Jun 06 @ 2:26 am
you can use only one tcv so nothing to do for mixing with tcvs, but is excellent for mixing with keyboard and 5.1 mode, Manquin DJ.
Posted Fri 30 Jun 06 @ 6:16 pm
Hello,
it depends on the use that you want some to make…i use Maya44 USB…goes is with the TCCD's that with the sure TCV's…you must occupy an other door USB…but second me it is best…also the ESI U46 DJ second me is optimal…in order to use an external audio card but you must acquire the version of VirtualDJ Professional (FULL)...confronts them click on the link…
http://www.virtualdj.com/purchase/ (VDJ PRO)
http://www.audiotrak.net/maya44usb.htm (Maya44 USB)
http://www.esi-pro.com/viewProduct.php?pid=60 (ESI U46 DJ)
DjRudy78 DiJ
Posted Sat 01 Jul 06 @ 1:15 am
phillydjPRO InfinityModeratorMember since 2004
if u have the money ...i would jump on todays special ..Vdj Pro is going for 90 Dollars
Posted Sat 01 Jul 06 @ 1:51 am
yes but is only for users that had been registered one year ago and that had been participating occasionally in forums.
Posted Sun 02 Jul 06 @ 1:51 am
