Forum: VirtualDJ Skins
Topic: Help with modifying skin
What's the syntax for "select headphone and active shortcuts" This skin thing is just too much for me.
Posted Wed 28 Jun 06 @ 10:02 pm
For the headphone switch is action="select" chan="1" or button action="select" chan="2"
Thanks man, which XML editor do you use?
good old notepad is the easiest for XML , nothing special needed. For the bmp either paint will work.
The best way to learn script is to read someone elses. I know this sounds like a rip off, but the aim is to learn the structure. If you need any help, drop me a line and I will try to help any way I can.
