juggernaut32
Your not alone. I had the same problem you have, and it drove me nuts!!! I tried talking to there tech support, and they made me run around in circles and never gave me a solution. my Honestly opinion, get a maya sound card, or something like it. you won't be disapointed. I could not trust the mk2 with it's
unstable drivers, nor could I enjoy the powerful feature of TCV untill I switched sound cards. Straight up. The funny thing is with the maya as your sound card, you could also use the mk2 as a controler if you like, and won't have the problems your writing about. although in my case, I already got used to just using the maya without the mk2. You will also notice a big diffrence in the sound quality. Good luck.
Posted Tue 27 Jun 06 @ 9:06 am
