Would love to use it, as "echo out" is a feature I love...
But when I hit mute at end options in 2.0, it just plains mute, no echo at all...
PLEASE PLEASE FIX :) It's the BEST plugin here!!! :)
your fan,
dj in norway :)
your fan,
dj in norway :)
Posted Thu 17 Jun 04 @ 9:54 pm
I've this prob too.
Posted Thu 17 Jun 04 @ 11:54 pm
Please please kaleo :)
Can u fix? :)
I really like and need this great plugin of yours ... :)
- DJ ME - ;)
Can u fix? :)
- DJ ME - ;)
Posted Fri 18 Jun 04 @ 1:28 am
u know what REALLY strange....
Tried the echo again just now.... echo out that is..
And it worked on Deck 1, but NOT on Deck 2...
is that strange or what... ?
PLEASE :) I LOVE THIS PLUGIN...
It's sooo needed, works just like I thought.... Really good plugin! Sounds just like when hitting echo out on Pioneer mixer... and I use that effect on mixer alot...
Dj-in-need-in-norway :)
Posted Fri 18 Jun 04 @ 1:50 am
ok I will have a look at it ;)
Posted Fri 18 Jun 04 @ 7:18 am
Yup... I posted this a long time ago, but no one noticed... :s
http://www.virtualdj.com/forum/display.html?topic=4987
Posted Fri 18 Jun 04 @ 10:34 am
Thanx Kaleo ! :)
Posted Fri 18 Jun 04 @ 3:14 pm
hi again.... :)
Did you find any solution? :)
I'm so in love with that echo plugin ..... :)
Posted Sat 19 Jun 04 @ 4:26 pm
Please, understand that I have a real life out of the matrix.
Wait a little, I have my familly (my father and my mother) at home this week-end.
Posted Sun 20 Jun 04 @ 9:00 am
hehe... No problem kaleo! :)
Sorry for bugging...
And hope you have a really nice weekend with your family!
Dj In Norway
Dj In Norway
Posted Sun 20 Jun 04 @ 2:27 pm
...a solution should arrive soon ;)
Posted Tue 22 Jun 04 @ 7:19 pm
GREAT!!!!! ;)
thanx man!
thanx man!
Posted Tue 22 Jun 04 @ 8:17 pm
Great! Kaleo, you're GOLD! :P
Posted Wed 23 Jun 04 @ 5:53 pm
You have to replace TK Filter V2 by the new one (on the add-on page) and delete plug_in.xml in the Effect folder of VDJ.
By this way, your settings on TK Filter V2 and Echo V2 will be saved correctly ;)
Posted Wed 23 Jun 04 @ 6:05 pm
Thanks a lot Kaleo!!!! You are the man!! :)
They both are my favorite plugins! great work!
The echo-out is a killer, perfect to use if a beatmix "goes wrong", or you are going to change BMP to lower/higher..
A tip for new users (cool echo-out effect):
- press button (1) for B.A in depth
- press button (2) for mute at end
- put first slider to about 1 sec
- second slider to 4 beats
- third slider to full volume.
Result : very pro echo out, just like a proffesional Pioneer 500/600 mixer.... its GREAT!! thanx man!
Posted Thu 24 Jun 04 @ 1:59 pm
You're welcome :)
I am happy to make other users happy :)
Posted Thu 24 Jun 04 @ 3:11 pm
Happy? I'm in LOVE with this ECHO!! :) Great improvement Kaleo, now I can create great sounding filppin doubles with this effect! So I don't have to change anymore, awsome!!!
THX AGAIN!!
(oh just maybe one thing, when choosing beat sync, it still displays seconds when moving 1st slider. Maybe you could change that to beats? But that would be sugar on top:P )
Regards, erXon
THX AGAIN!!
Regards, erXon
Posted Thu 24 Jun 04 @ 3:41 pm
Kaleo!!
Need help!! :)
First of all, your effects are the best on the board..
And echo out is sooo cool, and worked well with earlier versions of effect/vdj
But there is a bug in 2.0 version! Can u please fix? :)
If the echo if left on (echo out) and you drag and drop a new song on to that deck, with echo on, VDJ starts skipping really bad, hanging, and even stop responding/crash!
Even worse if echo is on both decks, and u drag a new song to one of the decks, forgetting to turn echo off, VDJ crashes.. (or hangs for a long time!)
If u drag and drop (w/echo on) and press play really fast, there are problems..
At least for me! Anyone else having this problem?
Can U please please fix? ;) love and need this plugin :)
(buffer thats not emty or something else, dont know)
Hope to see a fix
Dj in Norway
Need help!! :)
Hope to see a fix
Dj in Norway
Posted Fri 25 Jun 04 @ 2:16 am
Ok.
I think I will auto-stop the effect on New song.
Should it be a good solution for you?
Posted Fri 25 Jun 04 @ 6:49 am
that would be great :)
thanx man!!!
very kind of you!
(by the way, making it stop, is that something that will compromize other use, or is it ok for evey use, that it stops...? just wondering...)
look forward to update.... thanx again, and love your effects! :) great work!!!
dj in norway
thanx man!!!
very kind of you!
dj in norway
Posted Fri 25 Jun 04 @ 9:10 am
