Hi,
I am in need of advise, when I try to drag a song from the database list to the deck it will not play? I then right click the mouse and select 'file Info' and it reads this:
Impossible to open C:\Documents and Settings\All Users\Documents\House1.wma with the WMA Decoder.
Now some of my songs do work but most of the time they don't??? I am using Windows XP.
Any HELP would be great?
oh and if this helps, i have been ripping the songs to Windows Media Player 10.
Thanks.
Thanks.
Posted Fri 23 Jun 06 @ 4:27 am
This is because you have the home edition of Virtual DJ, and your version doesn't support protected WMA files.
You should re-encode your tracks disableing the WMA protection, or re-encode in MP3.
Another solution would be to upgrade to Virtual DJ Pro, you can have a discount price.
If you buy Virtual DJ Pro, you will have support for WMA protected files and for lots of other things see the comparison page.
And great news: You will have VDJ 4.0 for free if you upgrade now to the Pro version.
Posted Fri 23 Jun 06 @ 11:44 am
