this little program is amazing!!
lets you use DirectX plugins in VDJ!!!! tested a few directX plugins I got (from Audition and other progs) - and they worked great....
Now you can use BOTH VST & DIRECTX plugins in VDJ! :)
This VST plugin is FREEWARE and lets you load up to 4 directX plugin into the rack vst plugin - amazing!!!
http://vincent.burel.free.fr/download/index.htm
(direct dowload) - fully working and FREE
There are also lotsa good effect that are not free at same site (http://www.vb-audio.com)
************ INSTALL NOTES *************
Install the program from the direct link above...
Copy the "FFX4" folder into your VDJ effect folder...
Restart VDJ - find the effect called "VB_FFX4" and drag & drop in channel you wanna use.
Load DirectX effect through this VST plugin ...
Thats it :)
Game - set - go - match! lol :)
Posted Wed 16 Jun 04 @ 7:26 pm
By the way, the same as for VST plugins apply to DirectX
Some will work GREAT, other OK, some BAD... and some not even at all :)
But still - a whole new world of plugins - now available :)
Posted Wed 16 Jun 04 @ 7:35 pm
I renamed the topic and placed it on the top, cause it's a HUGE discovery!! Thanks man :-)
FRUiT94
FRUiT94
Posted Wed 16 Jun 04 @ 8:11 pm
cool :)
Posted Wed 16 Jun 04 @ 8:14 pm
Dj-in-norway, i'll buy you a beer ;) thx man.
Posted Thu 17 Jun 04 @ 5:39 am
LOL :) thanx... hehe
Posted Thu 17 Jun 04 @ 6:12 am
It also means that we can use up to 6 effects at once wow it's really amazing! :-)
FRUiT94
FRUiT94
Posted Fri 18 Jun 04 @ 10:42 am
Where can we find DXplugins ?
Maybe it's a stupid question ?
Clax
Clax
Posted Fri 18 Jun 04 @ 11:47 am
I think we are going to add a DX section, but for the moment it's better to search for VSTs. I will create a new topic soon. You can search for DX plugin in google or else, type "DX plugin free" and you'll find a huge jungle too.
FRUiT94
FRUiT94
Posted Fri 18 Jun 04 @ 11:50 am
I'll try thanks Fruit
Posted Fri 18 Jun 04 @ 11:55 am
a DX section would be good... :)
Start here Clax:
http://www.directxfiles.com/plugins.htm
http://www.sonicspot.com/daplugins.html (DX & VST)
http://www.electronicmusicsearch.com/search/category.cfm?Category=31
http://www.databaseaudio.co.uk/plugins.php (over 300 VST & DX plugins...)
Start here Clax:
Posted Fri 18 Jun 04 @ 2:58 pm
Wow there's a lot of plugins on these sites.
I'll check as soon as possible
Thanks
Thanks
Posted Fri 18 Jun 04 @ 7:13 pm
yep :)
There are 1000's of VST & DirectX plugins, and many of them are free too :)
Posted Fri 18 Jun 04 @ 7:16 pm
Excellent! i have many Dx plug-inn's already so this was a dream find,
My only problem was the waves mastering package is just to heavy for my p.c. it causes skips when mixing, but i will try to optimise windows and see if that makes a difference,
Thanks again,
Keith.
Thanks again,
Keith.
Posted Sun 15 Aug 04 @ 10:11 am
Dj in Norway :
One word : Thank'ssssssssss !
I can also used my old sonic and sony DX plug in now !!!
Plouuummmm ! :)))
Plouuummmm ! :)))
Posted Thu 28 Oct 04 @ 2:19 pm
