i am trying to broadcast on the air and i am having a hard time when it says 8000 what else do i do and also went to get the number for ip and could not get to work so i just gave up.. do u know if 365 radio u can mix live there
Posted Mon 12 Jun 06 @ 7:42 am
do you use a router , and do your have a static ip?
Posted Mon 12 Jun 06 @ 11:38 am
i use a router
Posted Mon 12 Jun 06 @ 11:11 pm
You have to open port 8000 at router at yout IP of computer.
Posted Mon 12 Jun 06 @ 11:14 pm
i using a laptop could i use it wireless
Posted Tue 13 Jun 06 @ 2:32 am
how do i open the router 8000 do i open it in my laptop or the pc i dj off my laptop
Posted Tue 13 Jun 06 @ 7:46 am
Well, first of all you have to disable firewall in Windows at your laptop. Then you have to get access to your router and open port 8000 (if you use this one) in router firewall. Then it should work.
Posted Tue 13 Jun 06 @ 10:38 am
how do i open port 8000
Posted Tue 13 Jun 06 @ 8:36 pm
if you can email me at ********** showing me how i can open port 8000 on my computer i would be greatfull
Posted Tue 13 Jun 06 @ 8:40 pm
You have just to disable it in windows and OPEN it at router. To disable it in windows right click to connection that is for internet use (local area connection for example and click properties. then click on Firewall (if i am not wrong) and there you have to choose to enable or disable it. Just disable it and click ok.
Then you have to go into preferences of your router and there you have to find something like Virtual Server or Forwarding Rules. It depends of your router. There you can open port 8000 and set it to your local IP.
To make it easy: call your network administrator who configurated router for you ;)
Posted Tue 13 Jun 06 @ 11:50 pm
im not using a router i got verizon dsl and i got a direct line to my computer and i still cant get nobody to listen to me they cant even get to ip to listen the speed is 100 mbps i think is broadband or something
hit me up at *************
Posted Thu 15 Jun 06 @ 3:02 am
have you set it to broadcast from your machine ?
do you have a static ip adress?
have you got the right plugins for encoding
are you using ice cast or shout cast ?
and what version are you using.
if u want to chat more
add our msn skyfxlmedia@hotmail.co.uk
Posted Thu 15 Jun 06 @ 6:18 pm
my msn is at my blog it you need it.
Posted Fri 16 Jun 06 @ 1:52 pm
