Could the team or the moderators create a post especially to write the name of the plugins which works welle with VDJ ?
Thanks in advance to the team, the moderators, and all the users who will post their experiences.
Clax
Clax
Posted Tue 15 Jun 04 @ 5:27 pm
Done !
Please write here only the plug ins who works perfectely with VDJ.
Posted Tue 15 Jun 04 @ 5:46 pm
Thanks DJ Morris
Posted Tue 15 Jun 04 @ 5:49 pm
These one works:
BJ RingModulator
BJ Flanger
BJ Tremolo
BJ Wavechanger 2
--> www.bojo.dk
BJ RingModulator
BJ Flanger
BJ Tremolo
BJ Wavechanger 2
--> www.bojo.dk
Posted Tue 15 Jun 04 @ 6:14 pm
Classic Phaser
"The Classic Phaser emulates analog phasers from the 70’s and 80’s. These vintage phasers got their characteristic sound from the analog phase shifting filters used, unlike the delay lines used in most modern digital phasers. To get a deeper and fatter phasing effect, more filter stages were cascaded. The Classic Phaser works just like an analog phaser, and with selectable filter stages from 4 to 12, it can resemble anything from phaser pedals to expensive studio phasers from that time period"
Works pretty good :) ONLY THING IS THAT THE GRAPHICS will not show.
But 4 sliders are there in VDJ :
- Stages
- Upper
- Rate (Hz)
- Debth (%)
- Synk On/Off
(Strange that the other sliders are not there, guess there is a limit off 5 sliders in VDJ)
But those 5 sliders made some amazing phaser effects! :)
So - working - but not fully, but still pretty good :)
http://www.kjaerhusaudio.com/classic-phaser.php
![http://www.kjaerhusaudio.com/archives/classic_phaser_v101.zip](http://www.kjaerhusaudio.com/images/classic-phaser.gif)
- Stages
- Upper
- Rate (Hz)
- Debth (%)
- Synk On/Off
Posted Tue 15 Jun 04 @ 6:37 pm
dominion signal modelling device
"What is dominion?
If you were searching for a tool to shape the envelope of a signal, giving you total control of the signal's attack & sustain phase, dominion is certainly something for you!
But it's got more to offer...
A short overview of the features:
Envelope section. Adjust attack & sustain independently, regardless of input level. Plus, you have control over the envelopes' time constants. Imagine pulling a drummer up front or pushing him to the background by dragging just a single slider! Feel like moving the walls around him? Again, a single push enhances the room information or can make the sound really dry.
Imagine doing things like this with other instruments as well... :)
Saturation stage. Following digitalfishphones tradition, the plugin can help to reduce harshness often associated with digital recordings, giving back some warmth and life to your source by modelling classic analog equipment. The tonal character stays adjustable within a broad range.
High frequency details section. Similar to classic exciter circuits, this section allows you to brighten up a signal, giving transparency and depth by generating additional harmonics.
Non-clipping output stage. Like the endorphin compressor, a brickwall waveshaper circuit ensures that the output won't exceed -0.1dBFS, while remaining sonically clean "
http://www.digitalfishphones.com/main.php?item=2&subItem=4
![http://www.digitalfishphones.com/binaries/dominion_v1.2_PC.zip](http://www.digitalfishphones.com/images/screenshots/dominion.gif)
"What is dominion?
Works very well with VDJ - all sliders, graphics and all......
Posted Tue 15 Jun 04 @ 7:58 pm
Also working and good from same page
BLOCKFISH
is a versatile compressor with countless ways to shape the incoming audio.
Unlike many other digital compressors, BLOCKFISH has 'soul'. It likes to bite, but it can be tamed easily once you've learned how to use its potential.
SPITFISH
is a dead-easy to use de-esser, aimed mainly at mono or stereo vocal tracks. Just like classic analog de-essers, this unit dynamically filters out harsh, annoying s-like sounds that would otherwise 'spit' in your face.
FLOORFISH
is a simple expander / gate device, easy to set up and offers a broad variety of processing, ranging from slight expansion, backgound noise attenuation to extreme gating effects.
What's different from similar units is the ability to scan the source and adjust the transistion curve accordingly.
BLOCKFISH
SPITFISH
FLOORFISH
Posted Tue 15 Jun 04 @ 8:06 pm
Posted Tue 15 Jun 04 @ 8:26 pm
REALLY nice echo/delay that can be adjusted for BMP :)
Refero:
"A BPM-synced delay line combined with user control-auto-panning"
wow :) http://www.spiritcanyonaudio.com/vst.php
Other good VST at same page (not tested):
EMPIRE:
"Unobtrusive but deep reverb effect, combining reverb and a sidechain compression scheme"
Neutronium:
"BPM-synced lowpass filter with its own LFO"
Sputnik:
"BPM-synced delay line combined with a high-pass filter"
And more... that all sound pretty nice :)
Refero:
EMPIRE:
Neutronium:
Sputnik:
Posted Tue 15 Jun 04 @ 8:38 pm
I get very good results using Sonitus Ultrafunk VST-pluginpack.
http://www.directxfiles.com/manufacturers/ultrafunk_pack.htm
Reverb, gate, delay, multiband-equalizer, compressor/limiter, modulator, phase and even wha-wha effects.
all of these work like a charm, including the graph. interface
Here is an example : FXSurround
Posted Wed 16 Jun 04 @ 9:15 am
Hexaline
Ambient chorus / enhancer / stereo expander "This incredible free plugin has a unique feature: it can immediatly add warmth and complexity to the simplest sounds. With extreme settings, this effect can also generate special ambiences and bizarre sounds."
Works well with VDJ, both GUI (grapics) and sliders... freeware http://bigtick.pastnotecut.org/index.php?action=PROD&pcode=300
![http://bigtick.pastnotecut.org/index.php?action=SEND&fileid=300](http://bigtick.pastnotecut.org/pics/hexaline202.gif)
Posted Wed 16 Jun 04 @ 4:23 pm
This one works amazing with VDJ...
It's really a guitar plugin, but have a FX mode as well, with really great presets that worked so well with VDJ
http://www.amplitube.com/Main.html?prod_AT
"AmpliTube™ Plug-In Guitar Amp & FX Modeling Plug-In • Amp modeling • Stomp modeling • Post effects modeling • For MacOS® and Windows® • Separate Pre, EQ, Amp, Cabinet and Mic modeling • 1,260 different amp configurations can be emulated • 10 stomp, amp and post effects included • Based on must-have modern and vintage Amps and effects!"
BUT - it's not freeware/shareware :(
![http://www.amplitube.com/Main.html?prod_AT](http://www.amplitube.com/Picts/product/fig_01.jpg)
Posted Wed 16 Jun 04 @ 5:42 pm
![http://www.univers-sons.fr/us2K/exec/product?prod=ORANGEVOCOD](http://www.univers-sons.com//media/400/ORANGEVOCOD/ov_HI.gif)
orange Vocoder
Very cool to use
Cost=195€
You can purchase here
Posted Wed 16 Jun 04 @ 5:59 pm
Posted Wed 16 Jun 04 @ 7:23 pm
Posted Wed 16 Jun 04 @ 7:29 pm
Posted Thu 17 Jun 04 @ 8:40 pm
ROOMMAKER
"This project involves the design and implementation of a real-time reverberation unit. The interface gives complete user control of a number of reverberation effect parameters, all within a real-time environment.. "
DOWNLOAD
Very extented reverb/room plugin, with lotsa buttons to play with... found some nice effects :)
If you make too extreme effects, there will be a click in music before it kicks inn....
GUI works well with VJD
![http://www.cosc.brocku.ca/~bross/4f90/RoomMaker/RoomMaker.zip](http://www.cosc.brocku.ca/~bross/4f90/RoomMaker/RoomMakerScreenshot.jpg)
DOWNLOAD
Posted Fri 18 Jun 04 @ 3:55 am
Prodused some interesting effect with this one...
all from ambient sound to regular delay...
Some might like...
Kiesel FreeDelay LFO modulation
- The delay time can be modulated with a sinusoid Low Frequency Oscillator.
Stereo
- Adjustable phase difference between the left and right channel modulations.
Low-pass filter
- The feedback can be dampen with a low-pass filter.
Modes
- Tempo sync 3/2, 1/1, 2/3, Smooth Mode and Tunable to MIDI note.
GUI - and all buttons works with VDJ
HERE
Some might like...
![http://www.kiesel.is/products/freedelay/](http://www.kiesel.is/img/ui/freedelaybig.jpg)
Stereo
Low-pass filter
Modes
HERE
Posted Fri 18 Jun 04 @ 4:09 am
and one just for fun... a crazy little plugin... :)
it scratch for you!! hehe...really... but it sound a bit like your kid is playing with your turntable..crazy scratch :) lol...
but fun..hehe
LOOPSCRATCH
from site:
"This plugin is in early development, but its pretty fun to use. There's two modulators that act as the scratching and two variable delays that you can crossfade between to create further oddness. Will be updating this soon, so keep checking in to see."
Posted Fri 18 Jun 04 @ 4:20 am
![http://www.smartelectronix.com/refer.php?url=~magnus/files/ambience-demo-win-vst-2003-10-25.zip&mirror=true](http://www.smartelectronix.com/~magnus/images/ambience_mid.jpg)
SmartElectronix Ambience
(reverb)
pretty fun to play with.. and works with VDJ, both GUI and buttons... All from horrible hall sound to nice reverb... FREE
download
Posted Fri 18 Jun 04 @ 4:54 am
