Hey
I see that alot of you are using the maya44usb, well my problem is that the leds do not light up when i plug the line ports. They did come on once but then I unplugged everything to relocate my setup and it won't come on. I was able to configure the TVC and everything the time the LED's lit up but now nothing works with out the LED's comming on, does anyone know what I might be doing wrong. I am totally confused and at a loss as to why it won't work now.
Thanks in advance.
Am using the trial version.
AMD 64 Athlon 3500
Windows XP Professional
Thanks in advance.
AMD 64 Athlon 3500
Posted Fri 02 Jun 06 @ 9:50 pm
I figured it out well sort of the LED's still don't come on but the TVC's and everything is working, I had to get some wite and connect the TT's earth to the computer case and it works great.
Posted Fri 02 Jun 06 @ 11:42 pm
