In my first party i was playing CD on VDJ, but there was one problem music was so loud that it gives shock to CD-Rom. Can somebody help (i mean without writing music on PC)
Posted Fri 02 Jun 06 @ 3:35 pm
get a better cd rom .....or at least one with better anti-shock
Posted Fri 02 Jun 06 @ 4:19 pm
CD-rm wth ant-shock? Where can i get it?
Posted Sat 03 Jun 06 @ 9:34 am
You could also put some anti-vibrating structure under the computer.
If you have a little carpet or something that is a bit soft and could stop the vibrations it could work.
Posted Sat 03 Jun 06 @ 2:27 pm
Like porlon
Posted Mon 05 Jun 06 @ 10:34 am
Takes me back to the vinyl days when I had about 50 largish fattish women all over 50 doing the same dance together - It was Brendan's Gimme Some and I had to put my decks on some foam cushions to stop them jumping. (It was very very scary)
The same solution would probably work for CD players. Just make sure you don't block off ventilation underneath if there is any.
Posted Mon 05 Jun 06 @ 3:33 pm
