Topic: Thinking of buying this sound card
Tell me what you think of these specs. It was $269, and now it's $99. I do mostly VJ'ing with .vob's
Creative Sound Blaster Audigy 2 ZS Platinum DVD-Audio Playback And Internal I/O Drive
With THX certification, Advanced Resolution DVD-Audio playback and an internal I/O Drive the Sound Blaster Audigy 2 ZS Platinum is the definitive 24-bit advanced HD gaming solution with 8 channel 108dB SNR for unsurpassed audio fidelity.
Mfr. Part Number: 3946397
Audio Engine Not Applicable
Bus Interface PCI 2.1
Channel Output 5.1, 6.1, 7.1 Surround
External Ports/Connectors Info Not Available
Included In Box Cables, Manual; See Below
Included Software Lara Croft Tomb Raider; See Below
Number of Speakers Supported 7
Remote Control Yes
System Requirements Win98SE/2000/ME/XP/SP2; See Below
Warranty 90 Day Parts & Labour Limited
Wavetable Voices Not Applicable
More Information
Sound Blaster Audigy 2 delivers high-quality multi-channel recording and playback at up to 24-bit/96kHz. It is the first PC product to offer playback of Advanced Resolution DVD-Audio at an astonishing 24-bit/192kHz with a stunning Signal-to-Noise ratio of 106dB. Experience spectacular audio quality that has now redefined PC audio standards. With EAX ADVANCED HD, 6.1 speaker support and Dolby Digital EX support, movies and games will be experienced with a breathtaking level of immersion and intensity, while Firewire allows super-fast transfer of audio to external players.
INCLUDED SOFTWARE:
* Lara Croft Tomb Raider: The Angel of Darkness (Full Version Featuring EAX ADVANCED HD)
* Tom Clancy's Rainbow Six: Raven Shield (Full Version Featuring EAX ADVANCED HD)
* Cubasis VST Creative Edition
* FL 4 Studio Creative Edition
* Sound Blaster Audigy 2 ZS Feature Showcase Demonstration CD
* Creative DVD-Audio Sampler Disc
* Multi-language Installation and Application CD including Drivers for Windows 98SE, Me, 2000 SP2 and XP.
* Creative Applications including Creative MediaSource Go, Creative MediaSource Organizer, Creative MediaSource Player and more.
INCLUDED IN BOX:
* Sound Blaster Audigy 2 ZS PCI card
* Audigy 2 ZS Internal I/O Drive with infra-red receiver (8.27” Width x 2.05” Height x 7.68” Length).
* Joystick/MIDI Bracket
* Remote Control With Battery
* AD_LINK cable
* Power Converter Cable
* Multi-Language User Manual (On CD)
* Multi-Language Quick Start Guide Leaflet
* SoundFont Sample Banks
SYSTEM REQUIRMENTS:
* CD ROM: Yes
* CPU Speed: 450MHz
* CPU Type: Pentium II
* Disk Space: 600MB
* Memory (RAM): 64MB
* Operating System Compatibility: Windows 98SE, Me, 2000 SP2, Or XP
* Other: Intel, AMD or 100% Compatible Motherboard; Available PCI 2.1 Compliant Slot; Available Adjacent Slot for Joystick/MIDI bracket; Headphones or Amplified Speakers (Optional)
CONNECTORS:
* Line level out (Front, Rear, Centre, Subwoofer, Rear Centre), Digital Out for 5.1 support (6-channel SPDIF Output)
* Line In
* Microphone In
* FireWire Port
* Telephone Answering Device In
* Analog/Digital CD Audio In
* 15-pin MIDI/Joystick Port Extension Header
* Headphone Out (1/4" Stereo Jack With Volume Control)
* Line In 2 (1/4" Stereo Jack, Shared With Microphone In 2)
* Microphone In 2 (1/4" Jack With Gain Control)
* MIDI In And Out (Mini DIN)
* Optical SPDIF In And Out
* Coaxial SPDIF In And Out
* Stereo Auxiliary In (2 x RCA/Coaxial Jack)
* Infra-red Receiver
Posted Fri 26 May 06 @ 8:11 pm
This is an excellent soundcard lol, I have one of those mixing with tcvs and works really good; sound has an excellent quality for vobs since resamples up to 48hz and about the price you mentioned, $99? , where did you see that price? I paid about $200 for mine. Are you sure that is the platinum version with frontal part of the sound card? cause there's another audigy2 zs without that part that is very important and the price is almost the same that you said about $99 and it's only the pci part, greetings.
Posted Fri 26 May 06 @ 9:32 pm
It was $269 on clearance for $99. Thanks for the info on the resampling. I got over a terabyte of .vob's that will enjoy that!
Posted Tue 30 May 06 @ 3:01 am
