Topic: Console edition Vs Pro Edition
Hi,
I bought my Mk2 Hercules yesterday which came with Console Edition. I used the Pro Trial Version before this. The only differnces I can see are to do with the settings for sound cards, ie you can can't use it with two physical sound cards for example. Is there anything else missing, or any other reason I should buy the Pro Version.
Thanks
Posted Tue 23 May 06 @ 1:56 pm
Trial version is limited. Console version is limited too :) You can do a little more with console version than with trial. PRO version has a lot more features that console, believe me ;)
Go pro!
It doesn't seem to me that there are many benefits to Pro over Console edition that I would need.
What are the benefits?
a small comparison you can see here: http://www.virtualdj.com/products/comparison.html
all depends what you are missing in console version. If you don't need any more than console can offer you, stay at this version :)
You have always time to upgrade it to pro ;)
OK Thanks, I looked at the comparision.
The only thing I didn't understand was Pro is "Optimised for automatic use"?
What does that mean?
basicaly its means that you can leave it alone for long periods unatended and it will mix for you and ,make its own play, this is only a feature of the dj box sytem , and is designed for bars or pubs.
