Hi,
I am trying to download one of the samples from the downloads section of this site. Most of them I can get no problem, but the California Dreaming one for example says "Your level is not high enough to download this add-on".
What does this mean plz?
Thanks
Thanks
Posted Tue 23 May 06 @ 1:54 pm
The message subject should read "samples", not "sound effects", sorry.
While we are on the subject of sound effects though, I see most of the downloadable ones are for the Pro edition, some are for the home edition. I have the console edition.
Does that mean I can't use any of them?
Thanks
Thanks
Posted Tue 23 May 06 @ 2:08 pm
You have a Home Edition, so you can't get any addon labeled 'Pro level only'.
Sorry :/
Sorry :/
Posted Tue 23 May 06 @ 2:12 pm
Surely a sample is just a sound, rather than an addon which requires a specific version of VDJ?
Posted Tue 23 May 06 @ 2:14 pm
Yes basically a sample is a sound. The level doesn't mean your version can't read these samples, but it means that there's extended content for pro users.
Posted Tue 23 May 06 @ 2:18 pm
But that's pants!
Posted Tue 23 May 06 @ 2:19 pm
Thanks for your help though
Posted Tue 23 May 06 @ 2:21 pm
hiiii:) ten ku
Posted Thu 22 Jun 06 @ 4:35 pm
