Can VDJ work with multiple MIDI devices at the same time to control VDJ, are there any restrictions ?
Posted Mon 15 May 06 @ 6:09 pm
you can use multiple..
i use 2x hercules consoles for example (mk1 and mk2)
Posted Mon 15 May 06 @ 7:29 pm
Ok,
But does VDJ really use MIDI for the HDJC ? Normally you controll HDJC from code via HID/DirectInput and not MIDI.
Posted Mon 15 May 06 @ 7:35 pm
vdj sees the midi for Herc Console too yes;)
Just uncheck it as controller (native built-in support), and check "enable midi" instead... and you got Herc as a normal midi controller:)
Posted Mon 15 May 06 @ 7:41 pm
;-) Great .
Just asking for my controller project since i'm doing 2 MIDI based controllers (Like XP10) that i'm going to control VDJ with.
Posted Mon 15 May 06 @ 8:04 pm
cool;) looked in your blog...
Might be a cool controller;)
Posted Mon 15 May 06 @ 10:59 pm
The Mixer/Controller in my blog is actually not going to use this Dual MIDI thing. This is for another Controler tha't i'm working on. It's a MIDI based single controller like XP 10 with touch-sensitive jog-wheel in a small box (100mm * 160 mm). But with more buttons to controll VDJ than XP10. So, 2 units are needed for maximu fun ;-)
So far i got the prototype almost working 100% and VDJ are now reading my MIDI signals.
Posted Tue 16 May 06 @ 7:20 am
