hi, i can get sound out of my headphones but nothing coming from the speakers, the mk2 acts as your default soundcard doesent it?? any help would be much needed, thanx N
Posted Sun 14 May 06 @ 12:24 am
go to windows control pannel and check you have selected mk2 as ur sound card and that the volume is turned up
Posted Sun 14 May 06 @ 1:16 am
Maybe, you attached your headphone to your amp output and amp ath the headphone output. In the DJ console version you need to keep the pre listen button on the console pressed to prelisten. Check also the Settings in the VDJ config menu.
Ewout
Ewout
Posted Sun 14 May 06 @ 2:28 pm
