Hi. I have only recently bought Hercules Dj Control Mp3 along with VDJ. The problem I am having is this: as soon as I load the second track (to be mixed) on the deck and then try and mix it the sound becomes peculiar:the bass looses its power and the tunes get really sticky. I used VDJ before I bought the mixer and had the same problem. Why is that? I also have traktor DJ which never had anysuch probles with the sound. My laptop has a normal Conexant soundcard so I was thinking of buying a Hecules one so that i can finally be able to hear through the headphones as well. but will this do anything for the sound quality? Why is it that it sounds so sticky?Or should I just get my money back?
Any help would be much appreciated
Thank you!
M
Thank you!
M
Posted Fri 12 May 06 @ 5:52 pm
