Hello! I would be very appreciative if someone could help me because I need to know how to preview the mix. I have an Echo Indigo DJ soundcard. I need to be able to separate the channels so that I can preview the level and beats of the next song. For some reason, both channels come out of both the line out and the headphones. Sometimes when I press the headphones button on the console, I can hear the other cued up song playing very softly. When I try to configure the soundcard in Virtual DJ i have only one option. What am i missing here? Thanks alot! - Judith
Posted Fri 12 May 06 @ 1:00 am
Hello judithkatz
Try to install the asio driver for your suond card and if you can't found try this universal driver www.asio4all.com
Posted Fri 12 May 06 @ 7:49 am
Hi there..
Is your soundcard 5.1? or 3.1? I´m using a 5.1 sound card and my phones are plugged in the "rear" plug. It works just fine. I´ve activated also the "headphones on 4.1....." options at the config setup.
Good luck
Good luck
Posted Sat 13 May 06 @ 12:41 am
You need to upgrade to the Professoinal version to cue properly with the DJ MP3 console.
Posted Mon 15 May 06 @ 5:32 am
its a setting proplem on your soundcard select 4.1 for best resultats and you needn`t the pro for preview
Posted Mon 15 May 06 @ 10:44 am
