I have an AudioTrak Maya EX7 USB sound card, and can't get VDJ configured so that it uses different outputs for the different decks. Anyone have a solution for this? Here's a link to the card for more information http://www.audiotrak.net/mayaex7.htm . I've used this card for years with BPM Studio.
Thanks in advance.
Tommy
Thanks in advance.
Tommy
Posted Wed 10 May 06 @ 5:07 pm
Hi,
As long as you've got the asio drivers installed ok, all you should have to do is:
click on "config"
go to the sound cards tab
go to "advanced" on the list of different configurations
click the button to bring up the setup window (can't remember whats written on it)
Then just assingn outputs zero and one to deck 1 & outputs 2 & 3 to the right deck.
Should be as easy as that! (hopefully) :)
click on "config"
Posted Wed 10 May 06 @ 9:59 pm
